Giriş
Although the Ecodrive watches made by Citizen contain a rechargeable battery, after a long period of usage the battery is no longer able to hold a charge. When that occurs, it would be less expensive to replace the battery instead of buying a new watch. This guide demonstrates how to properly perform a battery replacement on a Citizen Ecodrive watch.
Neye ihtiyacın var
Remove pin from watch band link to obtain easier access to the back of the watch.
To close the back, use a watch press. (The watch press tool and a set of dies costs about $15.)
Pick one of the dies that just fits the outer edge of the bezel for the front side, and pick another one that just fits the outer edge of the back casing. Attach the die for the back on the top (the lever of the watch press) and the die for the face on the bottom (the base of the watch press).
Place the watch face down. Arrange the seal (if any), and put the watch back gently into position.
Squeeze the tool slowly and firmly until you hear it click into place. Some watches do not click, so check the progress as you squeeze.
To reassemble your device, follow the steps in reverse order.
48 farklı kişi bu kılavuzu tamamladı.
44 Yorum
How about citizen c605? How to open for replace capacitor?cheers
Before doing any repairs it might be a good idea to do these:
1. Place the watch to bright sunshine for one full day the dial facing straight to the sun.
2. After the sun treatment pull the knop fully out and keep it that way for 30 seconds (or more).
3. Press the knop back in and wait for 10 seconds.
4. If the watch now works normally, you saved the battery price and your fixing work…
5. If not, you unfortunately have to do as instructed here.
Good luck!
Does the Capacitor of an Eco-drive watch has a tendency to leak?
No Generally speaking electrolitic capacitors dry out from old age but these just lose their ability to hold a charge…. no leaking
Where can I get an adjustable wrench like the one in the picture?
