Ana içeriğe geç
Citroen C4 Grand Picasso Rear Wing Light Replacement
Neye ihtiyacın var
  1. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Broken rear light: adım 1, 1 resimden 1.
    • Make sure you find the right component for the correct side of your car.
    • You've broken your rear light. Unfortunately you can't just replace the transparent cover. The whole unit needs replacement.
  2. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Locate the internal panel opening: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • You can lift the cover carefully just by using a flexible plastic card or a flat screwdriver.
    • Locate the internal panel opening. Use the little dent on the top corner of the little cover to open it.
  3. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Lift and remove the little panel cover: adım 3, 1 resimden 1.
    • Lift the cover from the top right corner.
  4. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Locate screw and electric cable connector: adım 4, 1 resimden 1.
    • The top most electric connector will need your attention.
    • In order to remove the broken light you'll have to remove just 3 screws, two are behind the little panel. One is the one right most visible in the picture.
  5. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Unscrew the light unit: adım 5, 2 resimden 1. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Unscrew the light unit: adım 5, 2 resimden 2.
    • Unscrew the light unit with a 6 points star tip. Of the 3 screws, two are behind the panel and one is outside near the edge of the lid.
  6. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Disconnect the cable: adım 6, 1 resimden 1.
    • Disconnect the topmost cable connector. This is also the bigger one in size.
  7. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Note the screw hols and the connector: adım 7, 1 resimden 1.
    • Also the cabling connector is now detached.
    • Note the 3 holes left where the screws were removed.
  8. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Replace the light unit: adım 8, 1 resimden 1.
    • Connect the cable and fit the small cover lid.
    • Put the screws back to fix the light unit firmly.
    • With the new light, slide the cable in through the square hole and push the new unit in place.
    • Remove the broken unit, wipe the edges holding the unit clean. Now repeat these steps in reverse to fit the new light unit.
  9. Citroen C4 Grand Picasso  Rear Wing Light Replacement, Job done: adım 9, 1 resimden 1.
    • Unfortunately the unit is tight sealed and it is not possible to change only the transparent cover. In that way the light is well water tight and free of finger prints that may be left in tempering with replacing internal bits of the unit.
    • Time and money saved. Job done!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carlo Zinzani
199 İtibar
1 Kılavuz yazıldı
Bir Yorum
@uca What year is the vehicle that you are repairing? I only ask as I know certain cars have different design processes that make repairs different for each generation or model
Kuromi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 137
Her zaman: 3,153
