Giriş
Follow this guide to remove and replace a worn or damaged rake belt.
Neye ihtiyacın var
Disconnect the spark plug to prevent the engine from accidentally starting up during service:
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Push down on the main handle to tilt the over seeder back on its rear wheels.
Place some weights on the handle, or tie the handle down, to prevent the machine from falling forward.
Remove the four lock nuts securing the belt guard:
Two 1/2" lock nuts
Two 7/16" lock nuts
