Ana içeriğe geç
Classen Sod Cutter SC18AHDCA 2019 Blade Replacement
Neye ihtiyacın var
  1. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Safety precautions: adım 1, 2 resimden 1. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Before you begin, make sure that the machine is turned off.
    • For safety purposes, disconnect the spark plug.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement: adım 2, 1 resimden 1.
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Unscrew the blade: adım 3, 2 resimden 1. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Unscrew the blade: adım 3, 2 resimden 2.
    • Use a 1/2" socket wrench to remove the six 1 inch-long bolts securing both ends of the blade. You may need to use a 1/2" combination wrench to hold the nuts in place.
  4. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Remove the blade: adım 4, 2 resimden 1. Classen Sod Cutter SC18AHDCA 2019 Blade Replacement, Remove the blade: adım 4, 2 resimden 2.
    • The blade can be very sharp! Do not handle the blade from the cutting edge.
    • Grasp the back of the blade and slide it away from the mount.
    • Remove the blade.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
257.458 İtibar
529 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
141 Üyeler
17.895 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 1,586
