Ana içeriğe geç
Classique 087CQA Heating Element Replacement
Neye ihtiyacın var
  1. Classique 087CQA Heating Element Replacement, Heating Element: adım 1, 1 resimden 1.
    • Begin with the side with switches
    FixBot'a Sor
  2. Classique 087CQA Heating Element Replacement: adım 2, 2 resimden 1. Classique 087CQA Heating Element Replacement: adım 2, 2 resimden 2.
    • Remove the Phillips PH0 bit
    • Insert the bit into the screwdriver
    FixBot'a Sor
  3. Classique 087CQA Heating Element Replacement: adım 3, 1 resimden 1.
    • Unscrew the shell screw (1) with the screw driver
    • 5mm Phillips flat-head screw
    FixBot'a Sor
  4. Classique 087CQA Heating Element Replacement: adım 4, 1 resimden 1.
    • Flip the hair dryer over to the side without switches
    FixBot'a Sor
  5. Classique 087CQA Heating Element Replacement: adım 5, 1 resimden 1.
    • Unscrew the shell screw (1) with the screwdriver
    FixBot'a Sor
  6. Classique 087CQA Heating Element Replacement: adım 6, 2 resimden 1. Classique 087CQA Heating Element Replacement: adım 6, 2 resimden 2.
    • Remove the bit from the screwdriver and insert the Phillips PH2 bit
    FixBot'a Sor
  7. Classique 087CQA Heating Element Replacement: adım 7, 1 resimden 1.
    • Unscrew the remaining shell screws (5) with the screwdriver
    • 15mm Phillips round-head screws
    FixBot'a Sor
  8. Classique 087CQA Heating Element Replacement: adım 8, 2 resimden 1. Classique 087CQA Heating Element Replacement: adım 8, 2 resimden 2.
    • Gently pull the two sides apart
    • Separate each side
    FixBot'a Sor
  9. Classique 087CQA Heating Element Replacement: adım 9, 1 resimden 1.
    • Remove front grill
    FixBot'a Sor
  10. Classique 087CQA Heating Element Replacement: adım 10, 2 resimden 1. Classique 087CQA Heating Element Replacement: adım 10, 2 resimden 2.
    • Pull up and remove the heating element assembly
    FixBot'a Sor
  11. Classique 087CQA Heating Element Replacement: adım 11, 1 resimden 1.
    • Remove the outer sleeve and replace the heating element
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 1,040
