Ana içeriğe geç
Clean Lookah 710 Wax Coils
Neye ihtiyacın var
  1. Clean Lookah 710 Wax Coils, Remove the coil: adım 1, 1 resimden 1.
    • Remove the coil: Take the coil out of your device.
    • The coils will unscrew counter clockwise.
  2. Clean Lookah 710 Wax Coils: adım 2, 1 resimden 1.
    • Wipe off excess: Use a Q-tip and a little isopropyl to wipe off any excess wax inside the coil. Wipe around the walls and mop up any excess wax. Use a tissue and a little isopropyl to wipe down the outside of the coil.
  3. Clean Lookah 710 Wax Coils: adım 3, 1 resimden 1.
    • Soak it: Place the coil in a bowl of cleaning alcohol (90% Isopropyl alcohol) for 30 minutes.
  4. Clean Lookah 710 Wax Coils: adım 4, 2 resimden 1. Clean Lookah 710 Wax Coils: adım 4, 2 resimden 2.
    • Wipe outside: Remove the coil from the alcohol. Wipe off any alcohol around the outside of the coil. Wipe inside: Use a Q-tip and clean the inside of the coil gently. Don't press down on the quartz plate, which could damage it.
  5. Clean Lookah 710 Wax Coils: adım 5, 1 resimden 1.
    • Let it dry: Let the coil dry completely. This could take a few hours.
  6. Clean Lookah 710 Wax Coils: adım 6, 1 resimden 1.
    • Heat the Coil: Screw the coil back onto the Lookah vape, turn on the vape (5 clicks). Set the voltage to the highest setting. Then heat the coil 3 or 4 times. This will burn off the excess residue from the coil
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
James Mash
490 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 40
Son 30 gün: 160
Her zaman: 4,949
