Ana içeriğe geç
Cleaning 1985-1988 Volvo 740 Throttle Body
Neye ihtiyacın var
  1. Cleaning 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: adım 1, 2 resimden 1. Cleaning 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: adım 1, 2 resimden 2.
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Cleaning 1985-1988 Volvo 740 Throttle Body, Removing Throttle Body: adım 2, 1 resimden 1.
    • Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
  3. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 3, 1 resimden 1.
    • Locate throttle linkage cable assembly.
  4. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 4, 2 resimden 1. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 4, 2 resimden 2.
    • Twist the assembly clockwise.
  5. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 5, 1 resimden 1.
    • Slide both slackened cables off assembly’s guides.
  6. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 6, 2 resimden 1. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 6, 2 resimden 2.
    • Locate the two hoses on the top of the throttle body.
    • Gently lift the hoses off.
  7. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 7, 1 resimden 1.
    • Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
  8. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 8, 1 resimden 1.
    • Remove the intake tube from the throttle body.
  9. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 9, 1 resimden 1.
    • Locate wiring clip on the underside of the throttle body.
  10. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 10, 2 resimden 1. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 10, 2 resimden 2.
    • Press down on the locking mechanism before gently removing the wiring clip.
  11. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 11, 3 resimden 1. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 11, 3 resimden 2. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 11, 3 resimden 3.
    • Locate throttle linkage arm.
    • Open the locking clip with a flat head screwdriver.
    • Pry off the linkage arm with a flat head screwdriver.
  12. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 12, 3 resimden 1. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 12, 3 resimden 2. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 12, 3 resimden 3.
    • Locate the three 13mm nuts attaching the throttle body to the intake manifold.
    • Remove nuts with a 13mm crescent wrench.
  13. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 13, 1 resimden 1.
    • Lift the throttle body off of the intake manifold.
    • The manifold is now out of the engine bay and ready for cleaning or adjustment.
  14. Cleaning 1985-1988 Volvo 740 Throttle Body, Cleaning 1985-1988 Volvo 740 Throttle Body: adım 14, 2 resimden 1. Cleaning 1985-1988 Volvo 740 Throttle Body, Cleaning 1985-1988 Volvo 740 Throttle Body: adım 14, 2 resimden 2.
    • Cover the electrical contacts with a shop towel to prevent throttle body cleaner from inadvertently spilling over.
  15. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 15, 1 resimden 1.
    • Liberally apply throttle body cleaner to the inside of throttle body and butterfly valve.
    • Use a shop towel sprayed with cleaner to wipe off thick grime if severely dirtied.
  16. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 16, 2 resimden 1. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 16, 2 resimden 2.
    • Spray electrical cleaner on the metal contacts to blast away particles in the bracket.
    • Spray off the wiring clip that attaches to the throttle body inside the engine bay.
  17. Cleaning 1985-1988 Volvo 740 Throttle Body: adım 17, 1 resimden 1.
    • Apply a small amount of dielectric grease to the metal contacts to prevent corrosion.
Sonuç
To reinstall the throttle body after cleaning follow reverse directions for prerequisite guide #2
Bir başkası bu kılavuzu tamamladı.
Raymond
76 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G28
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 36
Her zaman: 8,028
