Ana içeriğe geç
Cleaning Logitech MX Master
Neye ihtiyacın var
    1. Cleaning Logitech MX Master, The Before Shot: adım 1, 1 resimden 1.
      • That's a lot of gunk!
      FixBot'a Sor
      Yorum Ekle
    2. Cleaning Logitech MX Master, Removing the Feet: adım 2, 2 resimden 1. Cleaning Logitech MX Master, Removing the Feet: adım 2, 2 resimden 2.
      • The mouse has four feet on the bottom, but only the two long ones need to be removed. I used the Jimmy from the Pro Tech Toolkit.
      • I didn't have new feet on hand, so I had to reuse the original ones. This is why there's no step for cleaning the adhesive off and putting new feet on.
      FixBot'a Sor
      Yorum Ekle
    3. Cleaning Logitech MX Master, Screw Time!: adım 3, 3 resimden 1. Cleaning Logitech MX Master, Screw Time!: adım 3, 3 resimden 2. Cleaning Logitech MX Master, Screw Time!: adım 3, 3 resimden 3.
      • Rev up those screwdrivers! The first wave consists of four PH1 and two T5 screws on the bottom.
      • Once those are taken care of, the mouse should be easy to pop open.
      FixBot'a Sor
      Yorum Ekle
    4. Cleaning Logitech MX Master, Popping it Open: adım 4, 2 resimden 1. Cleaning Logitech MX Master, Popping it Open: adım 4, 2 resimden 2.
      • When opening the mouse take into account the position of the clamps so you won't pop more than you want.
      FixBot'a Sor
      Yorum Ekle
    5. Cleaning Logitech MX Master, Ribbon cables.: adım 5, 1 resimden 1.
      • Pop the connector open with whatever tool you find works best, unless you're like me and accidentally pulled the cable out of the connector in the previous step.
      FixBot'a Sor
      Yorum Ekle
    6. Cleaning Logitech MX Master, Bottom Half: adım 6, 3 resimden 1. Cleaning Logitech MX Master, Bottom Half: adım 6, 3 resimden 2. Cleaning Logitech MX Master, Bottom Half: adım 6, 3 resimden 3.
      • This is the part where I realize I need better lighting.
      • Set the top half aside for now. Removal of the battery consists of three PH1 screws and one connector that really doesn't want to come loose.
      FixBot'a Sor
      Yorum Ekle
    7. Cleaning Logitech MX Master, Bottom Half (continued): adım 7, 3 resimden 1. Cleaning Logitech MX Master, Bottom Half (continued): adım 7, 3 resimden 2. Cleaning Logitech MX Master, Bottom Half (continued): adım 7, 3 resimden 3.
      • Time for a bit change! The PCB housing the switches for left and right clicks comes off with four P0 screws and another ZIF connector.
      • The scroll wheel assembly is held in with two P0 screws at the front. There's also a connector for the motor hiding under the ribbon cable for the PCB you just removed.
      • These screws aren't visible in this step, but can be seen in the previous one. I'm terrible at taking pictures.
      • You can see some of the debris causing my scrolling issues in the last photo.
      FixBot'a Sor
      Yorum Ekle
    8. Cleaning Logitech MX Master, Bottom PCB: adım 8, 2 resimden 1. Cleaning Logitech MX Master, Bottom PCB: adım 8, 2 resimden 2.
      • Three more P0 screws hold this one in place.
      • Be careful to put the little doohickey on the red wire back in place (I can't remember the name)
      • We can see the micro USB connector on the underside. Unfortunately, I can't upgrade it to USB-C with the equipment I have.
      • I have the equipment to clean it though! A can of compressed air was all I needed.
      FixBot'a Sor
      Yorum Ekle
    9. Cleaning Logitech MX Master, Scroll Wheel: adım 9, 3 resimden 1. Cleaning Logitech MX Master, Scroll Wheel: adım 9, 3 resimden 2. Cleaning Logitech MX Master, Scroll Wheel: adım 9, 3 resimden 3.
      • I couldn't get the wheel out of the assembly, but I was able to spin it with some compressed air. I didn't get it on video, but a big chunk of dust came flying out.
      • I apologize in advance for filming in portrait mode. Also, I failed to get a shot of the debris inside the wheel.
      • That spring on the bottom in the first picture will probably fall off. Make sure to keep track of it.
      • I took the assembly apart in an effort to get the wheel out - no dice. I don't know where this oddly shaped spring goes, possibly on this peg, but I left it out and it doesn't seem to be important.
      FixBot'a Sor
      Yorum Ekle
    10. Cleaning Logitech MX Master, Almost Done!: adım 10, 2 resimden 1. Cleaning Logitech MX Master, Almost Done!: adım 10, 2 resimden 2.
      • You can follow steps 5-8 in reverse in order to put the bottom back together.
      • The top just needs a bit of compressed air, no disassembly required.
      • You can press the buttons down to gain easier access to the debris.
      FixBot'a Sor
      Yorum Ekle
    11. Cleaning Logitech MX Master, Congratulations, you did it!: adım 11, 1 resimden 1.
      • After following steps 1-4 in reverse, your mouse is clean again! And probably cleaner than mine.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Insert conclusion here?
35 farklı kişi bu kılavuzu tamamladı.
Skylar
1.145 İtibar
1 Kılavuz yazıldı
Ekip
Donut Donut üyesi
Business
1 Üye
5 adet Kılavuz yazıldı
17Kılavuz Yorumları
I followed your guide and I found a problem when I put everything together again. Now I turn on the mouse and it’s broken. The battery leds just blink and it doesn’t respond to pressing the channel selection or connect buttons, it just doesn’t work or sincronizes with the dongle, just shows the battery leds blinking. Anyone has any suggestion? Many thanks.
Juan Suarez - Yanıt Paylaş
I have the same problem (all three LED’s blink green and no response to pressing channel selection or connect buttons) that Juan Suarez describes.
I would also be happy for any suggestions on how to fix the issue.
Max - Yanıt Paylaş
And? Did you find a way to fix it?
Nicholas Blair - Yanıt Paylaş
Unfortunately I did not.
Max - Yanıt Paylaş
Have you tried reseating the ribbon cables?
Skylar - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 178
Son 30 gün: 812
Her zaman: 119,609
