Ana içeriğe geç
Cleaning the Controller Buttons
Neye ihtiyacın var
  1. Cleaning the Controller Buttons, Cleaning the Controller Buttons: adım 1, 2 resimden 1. Cleaning the Controller Buttons, Cleaning the Controller Buttons: adım 1, 2 resimden 2.
    • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
    • Remove the back panel from the controller.
    FixBot'a Sor
    Yorum Ekle
  2. Cleaning the Controller Buttons: adım 2, 3 resimden 1. Cleaning the Controller Buttons: adım 2, 3 resimden 2. Cleaning the Controller Buttons: adım 2, 3 resimden 3.
    • Remove the 3 screws (4.8 mm Phillips head) from the back of the white box.
    • Remove the back panel of the joystick box.
    • There are many small plastic components loose in this box; be careful not to lose these.
    • Separate the rubber pads and plastic buttons from the controller.
    FixBot'a Sor
    Yorum Ekle
  3. Cleaning the Controller Buttons: adım 3, 2 resimden 1. Cleaning the Controller Buttons: adım 3, 2 resimden 2.
    • Using a soft cleaning material, clean the plastic buttons.
    • Using a toothpick, clean the pole slot, shown at the right of the Q-Tip.
    FixBot'a Sor
    Yorum Ekle
  4. Cleaning the Controller Buttons: adım 4, 2 resimden 1. Cleaning the Controller Buttons: adım 4, 2 resimden 2.
    • Using a damp, soft cleaning material, clean the rubber button pads.
    • To ensure that no electrical damage occurs, ensure that you dry the pieces completely after cleaning them.
    FixBot'a Sor
    Yorum Ekle
  5. Cleaning the Controller Buttons, Put it back together: adım 5, 1 resimden 1.
    • Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Follow these steps in reverse order to reassemble your device.
7 farklı kişi bu kılavuzu tamamladı.
Jason Gittler
135 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 56
Her zaman: 6,571
