Ana içeriğe geç
Cleaning the Fan Blades
Neye ihtiyacın var
    1. Cleaning the Fan Blades, PCB (Printed Circuit Board): adım 1, 1 resimden 1.
      • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    2. Cleaning the Fan Blades: adım 2, 1 resimden 1.
      • Pull the front and back cover apart.
      • Be careful not to pull the front cover off completely. It holds the wires.
      FixBot'a Sor
      Yorum Ekle
    3. Cleaning the Fan Blades: adım 3, 1 resimden 1.
      • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
      • Shock warning: Make sure the fan is unplugged before removing the circuit board.
      FixBot'a Sor
      Yorum Ekle
    4. Cleaning the Fan Blades: adım 4, 1 resimden 1.
      • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
      FixBot'a Sor
      Yorum Ekle
    5. Cleaning the Fan Blades: adım 5, 2 resimden 1. Cleaning the Fan Blades: adım 5, 2 resimden 2.
      • Remove the screws from the four corners of the circuit board.
      • Remove the circuit board from the top cover.
      • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
      FixBot'a Sor
      Yorum Ekle
    1. Cleaning the Fan Blades, Fan Blades: adım 6, 1 resimden 1.
      • Follow steps 1-4 to remove the front, back, and top covers of the fan to reach the fan blades.
      • Use a cloth to clean off dust clogged in between the fan blades.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Vivian Fong
97 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-46, Forte Fall 2012 Cal Poly, Team 15-46, Forte Fall 2012 üyesi
CPSU-FORTE-F12S15G46
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 80
Her zaman: 11,607
