Giriş
If you are having trouble adjusting the headband on your Skullcandy Mix Master DJ headphones, you may need to simply clean the slider tracks to remove any obstructions. This guide will show you how to that in just four few easy steps.
Neye ihtiyacın var
Remove the Skullcandy Mix Master DJ Headphones from any casing or protective gear.
Bir başkası bu kılavuzu tamamladı.
