Ana içeriğe geç
Cleaning/Degreasing Heat Sink
Neye ihtiyacın var
  1. Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: adım 1, 3 resimden 1. Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: adım 1, 3 resimden 2. Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: adım 1, 3 resimden 3.
    • Ensure the engine is off and cooled down before starting this guide.
    • Using a 5/16" socket or wrench, remove the three bolts holding the plastic cover on to the engine.
    • Lift away the plastic cover. Note that the starter is attached to the cover and will come off with it.
  2. Cleaning/Degreasing Heat Sink: adım 2, 2 resimden 1. Cleaning/Degreasing Heat Sink: adım 2, 2 resimden 2.
    • Using compressed air or a rag, clean debris from the flywheel.
  3. Cleaning/Degreasing Heat Sink, Cleaning/Degreasing Heat Sink: adım 3, 2 resimden 1. Cleaning/Degreasing Heat Sink, Cleaning/Degreasing Heat Sink: adım 3, 2 resimden 2.
    • Using compressed air and a rag, clean the heat sink.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Correya
239 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G15
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 417
