Ana içeriğe geç
ClickN Kids Tablet Camera Replacement
Neye ihtiyacın var
    1. ClickN Kids Tablet Camera Replacement, Camera: adım 1, 1 resimden 1.
      • Start on the side with the camera
      • Insert a plastic opening tool into the space between the screen and the back side.
      • The screen side is black, the back side is colored
      FixBot'a Sor
      Yorum Ekle
    2. ClickN Kids Tablet Camera Replacement: adım 2, 1 resimden 1.
      • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
      • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
      • The corners can be tricky. Make sure to separate the pieces all the way around the tablet before attempting to open it.
      FixBot'a Sor
      Yorum Ekle
    3. ClickN Kids Tablet Camera Replacement: adım 3, 1 resimden 1.
      • Lift the detached screen from the camera side until you can see the inside of the tablet.
      • Don't open too fast, or you might damage the ribbons cables.
      FixBot'a Sor
      Yorum Ekle
    4. ClickN Kids Tablet Camera Replacement: adım 4, 2 resimden 1. ClickN Kids Tablet Camera Replacement: adım 4, 2 resimden 2.
      • Be careful not to damage any wires or ribbon cables during this step.
      • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
      • There is a black tab behind the long ribbon cable. Lift up the black tab.
      • For the ribbon cable in the back, pull the black tabs on the side out.
      • Detach the ribbon cables connecting the screen to the motherboard.
      • Remove any tape that is holding down the ribbon cables. Set it aside.
      FixBot'a Sor
      Yorum Ekle
    5. ClickN Kids Tablet Camera Replacement: adım 5, 1 resimden 1.
      • Pull off the tape that holds the ribbon cable to the battery.
      FixBot'a Sor
      Yorum Ekle
    6. ClickN Kids Tablet Camera Replacement: adım 6, 2 resimden 1. ClickN Kids Tablet Camera Replacement: adım 6, 2 resimden 2.
      • Be careful not to damage the wires or ribbon cables.
      • Pull out the two black ends of the base on the motherboard.
      • Slide out the camera’s ribbon cable once the ends are loosened.
      FixBot'a Sor
      Yorum Ekle
    7. ClickN Kids Tablet Camera Replacement: adım 7, 3 resimden 1. ClickN Kids Tablet Camera Replacement: adım 7, 3 resimden 2. ClickN Kids Tablet Camera Replacement: adım 7, 3 resimden 3.
      • Use a plastic opening tool to pry the camera out of its place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Finney
562 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-4, Williams Spring 2015 Baylor, Team 4-4, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G4
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 1,171
