Ana içeriğe geç
ClickN Kids Tablet Touch Screen Display Replacement
Neye ihtiyacın var
    1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: adım 1, 1 resimden 1.
      • Start on the side with the camera. The screen side is black, the back side is colored
      • Insert a plastic opening tool into the space between the screen and the back side.
      FixBot'a Sor
      Yorum Ekle
    2. ClickN Kids Tablet Touch Screen Display Replacement: adım 2, 1 resimden 1.
      • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
      • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
      FixBot'a Sor
      Yorum Ekle
    3. ClickN Kids Tablet Touch Screen Display Replacement: adım 3, 1 resimden 1.
      • Lift the detached screen from the camera side until you can see the inside of the tablet.
      • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
      FixBot'a Sor
      Yorum Ekle
    4. ClickN Kids Tablet Touch Screen Display Replacement: adım 4, 2 resimden 1. ClickN Kids Tablet Touch Screen Display Replacement: adım 4, 2 resimden 2.
      • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
      • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
      • There is a black tab behind the long ribbon cable. Lift up the black tab.
      • For the ribbon cable in the back, pull the black tabs on the side out.
      • Detach the ribbon cables connecting the screen to the motherboard.
      • Remove any tape that is holding down the ribbon cables. Set it aside.
      • Once the ribbon cables are freed, separate the top and bottom sides.
      FixBot'a Sor
      Yorum Ekle
    5. ClickN Kids Tablet Touch Screen Display Replacement: adım 5, 2 resimden 1. ClickN Kids Tablet Touch Screen Display Replacement: adım 5, 2 resimden 2.
      • Remove the yellow tape on the right side. Easiest side to get.
      • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
      FixBot'a Sor
      Yorum Ekle
    6. ClickN Kids Tablet Touch Screen Display Replacement: adım 6, 1 resimden 1.
      • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
      • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
      • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
      FixBot'a Sor
      Yorum Ekle
    7. ClickN Kids Tablet Touch Screen Display Replacement: adım 7, 2 resimden 1. ClickN Kids Tablet Touch Screen Display Replacement: adım 7, 2 resimden 2.
      • Be careful not to damage the display or screen case.
      • Pull the display from the top side to detach it from the screen case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kevin Finney
562 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-4, Williams Spring 2015 Baylor, Team 4-4, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G4
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 47
Her zaman: 8,417
