Ana içeriğe geç
Giriş
How to close and seal bObi's cover after opening and addressing any internal repair.
Parçalar
Hiçbir parça belirtilmedi.
  1. Closing bObi's Cover Post-Repair, Top Cover: adım 1, 2 resimden 1. Closing bObi's Cover Post-Repair, Top Cover: adım 1, 2 resimden 2.
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. Closing bObi's Cover Post-Repair: adım 2, 3 resimden 1. Closing bObi's Cover Post-Repair: adım 2, 3 resimden 2. Closing bObi's Cover Post-Repair: adım 2, 3 resimden 3.
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. Closing bObi's Cover Post-Repair: adım 3, 3 resimden 1. Closing bObi's Cover Post-Repair: adım 3, 3 resimden 2. Closing bObi's Cover Post-Repair: adım 3, 3 resimden 3.
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. Closing bObi's Cover Post-Repair: adım 4, 3 resimden 1. Closing bObi's Cover Post-Repair: adım 4, 3 resimden 2. Closing bObi's Cover Post-Repair: adım 4, 3 resimden 3.
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. Closing bObi's Cover Post-Repair, Closing bObi's Cover Post-Repair: adım 5, 1 resimden 1.
    • Attach the circuit plugs from bObi's cover back on her main board.
    • The all white plug goes to the centre of the circuit board.
    • The smaller plug connects at the side, closer to bObi's left wheel.
  6. Closing bObi's Cover Post-Repair: adım 6, 3 resimden 1. Closing bObi's Cover Post-Repair: adım 6, 3 resimden 2. Closing bObi's Cover Post-Repair: adım 6, 3 resimden 3.
    • Lay down bObi's cover and line up the sides carefully.
    • Re-install the front wheel's screw.
    • Place the wheel back in its compartment so it points towards bObi's touch sensors. Push down to secure it on bObi.
    • Replace the dustbin contact point fastener on bObi and install its two screws.
  7. Closing bObi's Cover Post-Repair: adım 7, 2 resimden 1. Closing bObi's Cover Post-Repair: adım 7, 2 resimden 2.
    • Install the four screws that were previously found under the main brushes.
    • Place the small main brush fastener overtop the screw posts on bObi and reinstall the two thin screws which hold it in place.
    • Lay the main brush attachment in the open space.
  8. Closing bObi's Cover Post-Repair: adım 8, 2 resimden 1. Closing bObi's Cover Post-Repair: adım 8, 2 resimden 2.
    • Replace the corner pieces close to the dustbin and install the 2 screws securing them on bObi.
    • These corner pieces must line up correctly with the brush attachment and hold it in place.
    • Insert the dustbin before using bObi again.
Sonuç
Follow this guide or reverse the directions of the Opening bObi guide to reassemble your device.
2 farklı kişi bu kılavuzu tamamladı.
Chelsea
2.278 İtibar
31 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 176
