Ana içeriğe geç
Cloth Face Mask Nose Bridge Replacement
Neye ihtiyacın var
  1. Cloth Face Mask Nose Bridge Replacement, Nose Bridge: adım 1, 2 resimden 1. Cloth Face Mask Nose Bridge Replacement, Nose Bridge: adım 1, 2 resimden 2.
    • It's best to wash your mask before and after handling to ensure cleanliness.
    • Lay the mask flat on desired surface.
    • Optional: Steam mask with a clothing iron to completely flatten and remove wrinkles.
    • Caution: Never leave the clothing iron unattended. Use caution when ironing as the machine will be hot to the touch.
    • Measure out the width of your face mask.
  2. Cloth Face Mask Nose Bridge Replacement: adım 2, 2 resimden 1. Cloth Face Mask Nose Bridge Replacement: adım 2, 2 resimden 2.
    • Using a pen or pencil, mark the insertion point for the pipe cleaners.
    • A fabric pencil would be better suited for markings as it can be easily washed off.
  3. Cloth Face Mask Nose Bridge Replacement: adım 3, 1 resimden 1.
    • Seam rip where the elastic portion is. If there is no elastic present, then seam rip along the top portion of the mask.
    • Caution: Be mindful of where you place your fingers as it is possible to accidentally jab yourself with the seam ripper.
    • Consider using a thimble for protection.
  4. Cloth Face Mask Nose Bridge Replacement: adım 4, 2 resimden 1. Cloth Face Mask Nose Bridge Replacement: adım 4, 2 resimden 2.
    • Cut a 4” strip of pipe cleaner.
    • Use caution when cutting pipe cleaners with scissors.
  5. Cloth Face Mask Nose Bridge Replacement: adım 5, 1 resimden 1.
    • Position the pipe cleaner where the markings are and fold the fabric over.
    • You may also use this as an opportunity to test out the positioning of the pipe cleaners before sewing the hem.
  6. Cloth Face Mask Nose Bridge Replacement: adım 6, 1 resimden 1.
    • Sew around the pipe cleaner using desired stitch.
    • A basic running stitch is recommended for ease.
    • Try on the mask to ensure the fit is right. Bend the pipe cleaners to best suit your facial frame.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Kayla Vargas
157 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S3-G15, Cowan Spring 2021 Texas Tech, Team S3-G15, Cowan Spring 2021 üyesi
TTU-COWAN-S21S3G15
1 Üye
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 601
