Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The antenna connector connects the antenna to the radio. The antenna connector transmits the radio signal to the radio. Perform the guide on a flat non-conductive surface to avoid electrical shock and damage to your device.
Some steps in this guide require soldering. For information on how to solder, see the soldering guide.
  1. Turn the power switch, the leftmost knob, counterclockwise to off. Turn the power switch, the leftmost knob, counterclockwise to off.
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Turn the device around and firmly pull the power cable plug to remove it from the radio. Turn the device around and firmly pull the power cable plug to remove it from the radio.
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Unscrew the securing cap counterclockwise from the antenna connector. Unscrew the securing cap counterclockwise from the antenna connector.
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Gently pull the antenna cable to remove it from the back of the radio. Gently pull the antenna cable to remove it from the back of the radio.
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Unscrew the cap counterclockwise on the microphone plug to disconnect the cable. Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  6. Gently unplug the microphone plug.
    • Gently unplug the microphone plug.
  7. Manta Tornavida Seti
    112 bits for every fix.
    Upgrade Your Toolbox
  8. Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver. Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  9. Gently life and remove the top cover. Gently life and remove the top cover. Gently life and remove the top cover.
    • Gently life and remove the top cover.
  10. Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio. Carefully flip the radio over. Carefully flip the radio over.
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  11. Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver. Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  12. Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far. Gently lift and remove the case cover. Gently lift and remove the case cover.
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
  13. De-solder the yellow wire that is connected to the antenna connector, with a soldering iron and the desoldering wick. During reassembly you will need to solder the components back together.
    • De-solder the yellow wire that is connected to the antenna connector, with a soldering iron and the desoldering wick.
    • During reassembly you will need to solder the components back together.
  14. The wire may still be hot, so let it sit for 30 seconds before continuing.
    • The wire may still be hot, so let it sit for 30 seconds before continuing.
    • Detach wire from back of antenna connector.
  15. Use a wrench to unscrew the nut counterclockwise, that secures the antenna connector to the device.
    • Use a wrench to unscrew the nut counterclockwise, that secures the antenna connector to the device.
  16. Remove the securing nut and washer from the antenna connector.
    • Remove the securing nut and washer from the antenna connector.
  17. Gently pull the antenna connector through its hole into the case. Gently pull the antenna connector through its hole into the case.
    • Gently pull the antenna connector through its hole into the case.
Sonuç
danperoni
485 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S11G37
4 Üyeler
9 adet Kılavuz yazıldı
3 Yorum
Don't bother with the solder wick. Heat the metal tip, pull the wire away with needle nose pliers. This is a rare repair.
rrmanning06 - Yanıt
If the radio is not transmitting, it is a rare thing, this wire could be broken. Solid wire on Galaxy radios, lots of vibration in the vehicle.
rrmanning06 - Yanıt
Ok I've got a question for you guy's. I've made some antennas changes and ran some ground straps and stuff to get rid of some of my static and I went to hook up my SWR meter and I couldn't get it to screw in the back of the radio so pulled it out and realized that the inner part of the coax plug pushed in. So I took the cover off the radio and checked it out and pushed it back in, the wire is still in good condition and connected good on both ends,but is it ok to use, or should I put a new plug on the radio?
Evan Slater - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 1,588
