Ana içeriğe geç
Cobra 29 LTD Classic Power Port Replacement
Neye ihtiyacın var
  1. Cobra 29 LTD Classic Power Port Replacement, Power Cable: adım 1, 2 resimden 1. Cobra 29 LTD Classic Power Port Replacement, Power Cable: adım 1, 2 resimden 2.
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Power Port Replacement: adım 2, 2 resimden 1. Cobra 29 LTD Classic Power Port Replacement: adım 2, 2 resimden 2.
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Cobra 29 LTD Classic Power Port Replacement, Antenna Cable: adım 3, 2 resimden 1. Cobra 29 LTD Classic Power Port Replacement, Antenna Cable: adım 3, 2 resimden 2.
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Power Port Replacement: adım 4, 2 resimden 1. Cobra 29 LTD Classic Power Port Replacement: adım 4, 2 resimden 2.
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Cobra 29 LTD Classic Power Port Replacement, Microphone: adım 5, 2 resimden 1. Cobra 29 LTD Classic Power Port Replacement, Microphone: adım 5, 2 resimden 2.
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  6. Cobra 29 LTD Classic Power Port Replacement: adım 6, 1 resimden 1.
    • Gently unplug the microphone plug.
  7. Cobra 29 LTD Classic Power Port Replacement, Outer Cover: adım 7, 2 resimden 1. Cobra 29 LTD Classic Power Port Replacement, Outer Cover: adım 7, 2 resimden 2.
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  8. Cobra 29 LTD Classic Power Port Replacement: adım 8, 3 resimden 1. Cobra 29 LTD Classic Power Port Replacement: adım 8, 3 resimden 2. Cobra 29 LTD Classic Power Port Replacement: adım 8, 3 resimden 3.
    • Gently life and remove the top cover.
  9. Cobra 29 LTD Classic Power Port Replacement: adım 9, 3 resimden 1. Cobra 29 LTD Classic Power Port Replacement: adım 9, 3 resimden 2. Cobra 29 LTD Classic Power Port Replacement: adım 9, 3 resimden 3.
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  10. Cobra 29 LTD Classic Power Port Replacement: adım 10, 2 resimden 1. Cobra 29 LTD Classic Power Port Replacement: adım 10, 2 resimden 2.
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  11. Cobra 29 LTD Classic Power Port Replacement: adım 11, 3 resimden 1. Cobra 29 LTD Classic Power Port Replacement: adım 11, 3 resimden 2. Cobra 29 LTD Classic Power Port Replacement: adım 11, 3 resimden 3.
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
  12. Cobra 29 LTD Classic Power Port Replacement, Power Port: adım 12, 3 resimden 1. Cobra 29 LTD Classic Power Port Replacement, Power Port: adım 12, 3 resimden 2. Cobra 29 LTD Classic Power Port Replacement, Power Port: adım 12, 3 resimden 3.
    • De-solder the yellow wire that is connected to the power port, with a soldering iron and the desoldering wick.
    • During reassembly you will need to resolder the components back together.
  13. Cobra 29 LTD Classic Power Port Replacement: adım 13, 1 resimden 1.
    • The wire may still be hot, so let it sit for 30 seconds before continuing.
    • Remove the yellow wire from the power port.
  14. Cobra 29 LTD Classic Power Port Replacement: adım 14, 1 resimden 1.
    • De-solder the black wire that is connected to the power port, with a soldering iron and the desoldering wick.
  15. Cobra 29 LTD Classic Power Port Replacement: adım 15, 1 resimden 1.
    • Remove the black wire from the power port.
  16. Cobra 29 LTD Classic Power Port Replacement: adım 16, 1 resimden 1.
    • Unscrew the two 6mm Phillips screws counterclockwise, using a #1 Phillips head screwdriver.
    • If screws have lock-tight glue on them, use a strong force to initially remove the screws from the device.
  17. Cobra 29 LTD Classic Power Port Replacement: adım 17, 2 resimden 1. Cobra 29 LTD Classic Power Port Replacement: adım 17, 2 resimden 2.
    • Gently pull the power port out of the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Noah Negrey
349 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S11G37
4 Üyeler
9 adet Kılavuz yazıldı
4 Yorum
Difficulty Difficult? this is the easiest thing you can do to one of these radios.
bassblaster505 - Yanıt
thank you, i’m hoping this will help but i doubt it, i had too big of a fuse in mine and it took a spike hit and lost all power a few years back but i’d really like to get this fixed.
BOB MCMILLAN - Yanıt
Any idea what the board pin hole number is that the black cord from the negative goes into? I’ve got a 2018 29 LX
Keith Nicola - Yanıt
Not sure. There is a partial schematic available at www.cbtricks.com
Tom Capehart -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 50
Her zaman: 6,547
