Ana içeriğe geç
Coby DVD-R11000 3-Pin Power Cable Replacement
Neye ihtiyacın var
  1. Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: adım 1, 3 resimden 1. Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: adım 1, 3 resimden 2. Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: adım 1, 3 resimden 3.
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 3-Pin Power Cable Replacement: adım 2, 3 resimden 1. Coby DVD-R11000 3-Pin Power Cable Replacement: adım 2, 3 resimden 2. Coby DVD-R11000 3-Pin Power Cable Replacement: adım 2, 3 resimden 3.
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
  3. Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: adım 3, 2 resimden 1. Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: adım 3, 2 resimden 2.
    • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
    • Remove the wire from the circuit board.
Sonuç
Andrew
501 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Shastany Fall 2014 UMass Dartmouth, Team 1-6, Shastany Fall 2014 üyesi
UMASSD-SHASTANY-F14S1G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 431
