Ana içeriğe geç
Coby DVD-R11000 Circuit Boards Replacement
Neye ihtiyacın var
  1. Coby DVD-R11000 Circuit Boards Replacement, Outer Casing: adım 1, 3 resimden 1. Coby DVD-R11000 Circuit Boards Replacement, Outer Casing: adım 1, 3 resimden 2. Coby DVD-R11000 Circuit Boards Replacement, Outer Casing: adım 1, 3 resimden 3.
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 Circuit Boards Replacement: adım 2, 3 resimden 1. Coby DVD-R11000 Circuit Boards Replacement: adım 2, 3 resimden 2. Coby DVD-R11000 Circuit Boards Replacement: adım 2, 3 resimden 3.
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
  3. Coby DVD-R11000 Circuit Boards Replacement, 3-Pin Power Cable: adım 3, 2 resimden 1. Coby DVD-R11000 Circuit Boards Replacement, 3-Pin Power Cable: adım 3, 2 resimden 2.
    • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
    • Remove the wire from the circuit board.
  4. Coby DVD-R11000 Circuit Boards Replacement, Circuit Boards: adım 4, 2 resimden 1. Coby DVD-R11000 Circuit Boards Replacement, Circuit Boards: adım 4, 2 resimden 2.
    • Position the DVD player so that the side with golden circuit board, where the power cord was plugged into, is closest to you.
    • Remove the black wire with the 6-pin white adapter, which is adjacent to the other three pin adapter wires on the golden circuit board.
  5. Coby DVD-R11000 Circuit Boards Replacement: adım 5, 3 resimden 1. Coby DVD-R11000 Circuit Boards Replacement: adım 5, 3 resimden 2. Coby DVD-R11000 Circuit Boards Replacement: adım 5, 3 resimden 3.
    • Position the DVD player so that the back panel is facing you.
    • Remove the three wires with the white pin adapters from the golden circuit board.
  6. Coby DVD-R11000 Circuit Boards Replacement: adım 6, 3 resimden 1. Coby DVD-R11000 Circuit Boards Replacement: adım 6, 3 resimden 2. Coby DVD-R11000 Circuit Boards Replacement: adım 6, 3 resimden 3.
    • Remove the four half inch screws, located at each corner of the golden circuit board, using the Phillips #1 screwdriver.
    • Place the blue plastic tool opener underneath the side of the circuit board and carefully remove it from the DVD player.
  7. Coby DVD-R11000 Circuit Boards Replacement: adım 7, 3 resimden 1. Coby DVD-R11000 Circuit Boards Replacement: adım 7, 3 resimden 2. Coby DVD-R11000 Circuit Boards Replacement: adım 7, 3 resimden 3.
    • Position the DVD player so that the front is facing you.
    • Using the tweezers and the blue plastic opening tool, disconnect the ribbon cables from the green circuit board where the I/O ports are attach to.
  8. Coby DVD-R11000 Circuit Boards Replacement: adım 8, 3 resimden 1. Coby DVD-R11000 Circuit Boards Replacement: adım 8, 3 resimden 2. Coby DVD-R11000 Circuit Boards Replacement: adım 8, 3 resimden 3.
    • Remove the three wires with the white pin adapters from the green circuit board that you just disconnected the ribbon wires from.
  9. Coby DVD-R11000 Circuit Boards Replacement: adım 9, 3 resimden 1. Coby DVD-R11000 Circuit Boards Replacement: adım 9, 3 resimden 2. Coby DVD-R11000 Circuit Boards Replacement: adım 9, 3 resimden 3.
    • Remove the seven 1cm screws located on the back panel of the outer casing, in between the I/O ports, with the Phillips #1 screwdriver
    • Grab the sides of the back panel and remove it from the DVD player.
  10. Coby DVD-R11000 Circuit Boards Replacement: adım 10, 2 resimden 1. Coby DVD-R11000 Circuit Boards Replacement: adım 10, 2 resimden 2.
    • Remove the two 1cm screws that are circled in red.
Sonuç
Andrew
501 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Shastany Fall 2014 UMass Dartmouth, Team 1-6, Shastany Fall 2014 üyesi
UMASSD-SHASTANY-F14S1G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 520
