Ana içeriğe geç
Coby DVD209 4-Pin Ribbon Cable Replacement
Neye ihtiyacın var
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: adım 1, 3 resimden 1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: adım 1, 3 resimden 2. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: adım 1, 3 resimden 3.
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: adım 2, 3 resimden 1. Coby DVD209 4-Pin Ribbon Cable Replacement: adım 2, 3 resimden 2. Coby DVD209 4-Pin Ribbon Cable Replacement: adım 2, 3 resimden 3.
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: adım 3, 3 resimden 1. Coby DVD209 4-Pin Ribbon Cable Replacement: adım 3, 3 resimden 2. Coby DVD209 4-Pin Ribbon Cable Replacement: adım 3, 3 resimden 3.
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: adım 4, 3 resimden 1. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: adım 4, 3 resimden 2. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: adım 4, 3 resimden 3.
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yufay Chow
92 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S10G36
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,007
