1. Press the eject button to view the laser inside. Using the blue plastic tool and the tweezers, remove the ribbon cable. Using the blue plastic tool and the tweezers, remove the ribbon cable.
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver. Do not lift the top of the DVD player too quickly because there are wires attached on the inside. Pry the top of the device open from the right side where the buttons are located.
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board. Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Position the DVD player so that the power and AVI ports are facing you. Pull the white cable with the blue adapters off of the circuit boards. Pull the white cable with the blue adapters off of the circuit boards.
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
  5. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  6. Using the plastic opening tool and your finger, push on the black tab on the inner part of the power port and lift the bottom outer portion of the power port with the plastic opening tool simultaneously. Lift the power port out of the its slot. Lift the power port out of the its slot.
    • Using the plastic opening tool and your finger, push on the black tab on the inner part of the power port and lift the bottom outer portion of the power port with the plastic opening tool simultaneously.
    • Lift the power port out of the its slot.
  7. Remove the four 5mm screws circled in red. Place the blue plastic tool opener underneath the circuitboard and lift up gently. Place the blue plastic tool opener underneath the circuitboard and lift up gently.
    • Remove the four 5mm screws circled in red.
    • Place the blue plastic tool opener underneath the circuitboard and lift up gently.
  8. Unplug the two, 3-pin ribbon cables, which are attached to the circuitboard. For the other circuit board (the one connected to the AVI ports) there are three 6.35mm screws to remove on the outside of the device. For the other circuit board (the one connected to the AVI ports) there are three 6.35mm screws to remove on the outside of the device.
    • Unplug the two, 3-pin ribbon cables, which are attached to the circuitboard.
    • For the other circuit board (the one connected to the AVI ports) there are three 6.35mm screws to remove on the outside of the device.
  9. Remove the four 5mm screws circled in red. Place the plastic opening tool underneath the circuit board, and lift up genttly. As you lift up, slide the circuitboard in a direction away from the AVI ports. Place the plastic opening tool underneath the circuit board, and lift up genttly. As you lift up, slide the circuitboard in a direction away from the AVI ports.
    • Place the plastic opening tool underneath the circuit board, and lift up genttly. As you lift up, slide the circuitboard in a direction away from the AVI ports.
  10. On the circuit board with the Power Port, de-solder the circled areas on the back to remove the Power port. On the circuit board with the Power Port, de-solder the circled areas on the back to remove the Power port.
    • On the circuit board with the Power Port, de-solder the circled areas on the back to remove the Power port.
  11. On the circuit board with the AVI Port, de-solder the circled areas on the back to remove the AVI Port. On the circuit board with the AVI Port, de-solder the circled areas on the back to remove the AVI Port.
    • On the circuit board with the AVI Port, de-solder the circled areas on the back to remove the AVI Port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yufay Chow
92 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S10G36
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 335
