Ana içeriğe geç
Coby KYROS MID7125 Side Lock Button Replacement
Neye ihtiyacın var
    1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: adım 1, 1 resimden 1.
      • Begin by removing back panel using the large opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Coby KYROS MID7125 Side Lock Button Replacement: adım 2, 3 resimden 1. Coby KYROS MID7125 Side Lock Button Replacement: adım 2, 3 resimden 2. Coby KYROS MID7125 Side Lock Button Replacement: adım 2, 3 resimden 3.
      • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Coby KYROS MID7125 Side Lock Button Replacement: adım 3, 1 resimden 1.
      • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
      • Review Battery Replacement for details on how to remove battery.
      FixBot'a Sor
      Yorum Ekle
    4. Coby KYROS MID7125 Side Lock Button Replacement: adım 4, 2 resimden 1. Coby KYROS MID7125 Side Lock Button Replacement: adım 4, 2 resimden 2.
      • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
      FixBot'a Sor
      Yorum Ekle
    5. Coby KYROS MID7125 Side Lock Button Replacement: adım 5, 1 resimden 1.
      • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
      • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
      FixBot'a Sor
      Yorum Ekle
    6. Coby KYROS MID7125 Side Lock Button Replacement: adım 6, 1 resimden 1.
      • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
      • Reverse steps 1-5 to reassemble.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Benjamin Foley
125 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G2
3 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 34
Her zaman: 499
