Ana içeriğe geç
Coby KYROS MID7125 Side Lock Button Replacement
Neye ihtiyacın var
  1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: adım 1, 1 resimden 1.
    • Begin by removing back panel using the large opening tool.
  2. Coby KYROS MID7125 Side Lock Button Replacement: adım 2, 3 resimden 1. Coby KYROS MID7125 Side Lock Button Replacement: adım 2, 3 resimden 2. Coby KYROS MID7125 Side Lock Button Replacement: adım 2, 3 resimden 3.
    • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
  3. Coby KYROS MID7125 Side Lock Button Replacement: adım 3, 1 resimden 1.
    • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
    • Review Battery Replacement for details on how to remove battery.
  4. Coby KYROS MID7125 Side Lock Button Replacement: adım 4, 2 resimden 1. Coby KYROS MID7125 Side Lock Button Replacement: adım 4, 2 resimden 2.
    • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
  5. Coby KYROS MID7125 Side Lock Button Replacement: adım 5, 1 resimden 1.
    • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
    • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
  6. Coby KYROS MID7125 Side Lock Button Replacement: adım 6, 1 resimden 1.
    • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
    • Reverse steps 1-5 to reassemble.
Sonuç
Benjamin Foley
125 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G2
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 299
