Ana içeriğe geç
Coby Kyros MID7012 Battery Replacement
Neye ihtiyacın var
    1. Coby Kyros MID7012 Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Wedge the metal spudger in between the faceplate and the body of the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Coby Kyros MID7012 Battery Replacement: adım 2, 2 resimden 1. Coby Kyros MID7012 Battery Replacement: adım 2, 2 resimden 2.
      • Carefully pry the faceplate away from the body of the tablet.
      FixBot'a Sor
      Yorum Ekle
    3. Coby Kyros MID7012 Battery Replacement: adım 3, 1 resimden 1.
      • Carefully lift the screen and set it face down on a soft surface to not scratch it.
      FixBot'a Sor
      Yorum Ekle
    4. Coby Kyros MID7012 Battery Replacement: adım 4, 3 resimden 1. Coby Kyros MID7012 Battery Replacement: adım 4, 3 resimden 2. Coby Kyros MID7012 Battery Replacement: adım 4, 3 resimden 3.
      • Carefully pry the battery away from the body of the tablet using the plastic spudger.
      FixBot'a Sor
      Yorum Ekle
    5. Coby Kyros MID7012 Battery Replacement: adım 5, 2 resimden 1. Coby Kyros MID7012 Battery Replacement: adım 5, 2 resimden 2.
      • Using a soldering iron heat up the location where the wire meets the motherboard. Remove the red wire first, then the black wire.
      • Clip the grey wire about an inch from the ribbon using a sharp object.
      • Here are some tips on how to Solder.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Daniel Ulrich
494 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-4, Harley Fall 2016 IUPUI, Team 3-4, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S3G4
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 1,670
