Ana içeriğe geç
Coby Kyros MID7125 Battery Replacement
  1. Coby Kyros MID7125 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
  2. Coby Kyros MID7125 Battery Replacement: adım 2, 1 resimden 1.
    • Locate battery. The battery is the silver coated square shaped device on the top of the motherboard.
  3. Coby Kyros MID7125 Battery Replacement: adım 3, 1 resimden 1.
    • There is a small ribbon cable located under the battery. running from the volume buttons underneath the batter to main logic board.
  4. Coby Kyros MID7125 Battery Replacement: adım 4, 1 resimden 1.
    • Knowing the location the ribbon cable, use plastic spudger to pry off battery.
  5. Coby Kyros MID7125 Battery Replacement: adım 5, 1 resimden 1.
    • After the battery is free from the logic board, find the positive and negative wires that connect the battery to the motherboard
  6. Coby Kyros MID7125 Battery Replacement: adım 6, 1 resimden 1.
    • Using a soldering gun, heat up both soldering points.
    • Remove wires from logic board
    • Clean up soldering joints with a desoldering sucker
    • Solder the new battery wires to the same soldering points as the old battery
    • Reverse steps 1-5 to put device back together
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan
108 İtibar
1 Kılavuz yazıldı
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 332
