Ana içeriğe geç
Coin Counter Disassembly
Neye ihtiyacın var
  1. Coin Counter Disassembly, Coin counter motherboard step 1: adım 1, 1 resimden 1.
    • I will be showing you how to look at the motherboard of a coin counter
    • the first step is to flip it to the back to see the little screws
    FixBot'a Sor
  2. Coin Counter Disassembly, 2nd step for motherboard: adım 2, 2 resimden 1. Coin Counter Disassembly, 2nd step for motherboard: adım 2, 2 resimden 2.
    • the second step is to remove the batteries.
    • To remove the batteries you have to take the top screw off
    • the second picture will show you how i toke out the screw in order to take out the batteries.to be safe when i get to the motherboard
    FixBot'a Sor
  3. Coin Counter Disassembly, 3rd step: adım 3, 3 resimden 1. Coin Counter Disassembly, 3rd step: adım 3, 3 resimden 2. Coin Counter Disassembly, 3rd step: adım 3, 3 resimden 3.
    • the third step is to take out the 3 little screws in which side of the circle
    • In total you should have 3 screws. make sure you don"t lose them in case you want to put it back together
    FixBot'a Sor
  4. Coin Counter Disassembly, 4th step: adım 4, 2 resimden 1. Coin Counter Disassembly, 4th step: adım 4, 2 resimden 2.
    • The fourth step is to remove the othere crews from the motherboard. You need to remove the crews in order to take out the motherboard.
    • You have to have the 4 screws if your switch the motherboard to a other one.
    FixBot'a Sor
  5. Coin Counter Disassembly, 5th step: adım 5, 2 resimden 1. Coin Counter Disassembly, 5th step: adım 5, 2 resimden 2.
    • The 5th step is the hardest part because you have to now remove the red and black wires from both sides so then you can see the motherboard.
    • Be very careful removing or pulling the wires because it can break the other wires which will not work anymore.
    FixBot'a Sor
  6. Coin Counter Disassembly, last step: adım 6, 1 resimden 1.
    • The last step is you got to the motherboard which was my goal. you could use the motherboard for other projects or just put it back for more a challenge.
    • My decisions was to put it back together, so then i can have more of a challenge. thank you for your time and i hoped this helped
    FixBot'a Sor
Sonuç
osmar
101 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 59
Her zaman: 627
