Ana içeriğe geç
ColecoVision Cartridge Reader Replacement
Neye ihtiyacın var
  1. ColecoVision Cartridge Reader Replacement, Cartridge Reader: adım 1, 1 resimden 1.
    • Flip the console upside down and remove the eight 15mm Phillips #1 screws.
  2. ColecoVision Cartridge Reader Replacement: adım 2, 2 resimden 1. ColecoVision Cartridge Reader Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger along the bottom rim of the front panel to safely remove the top of the console. Set aside the top.
  3. ColecoVision Cartridge Reader Replacement: adım 3, 2 resimden 1. ColecoVision Cartridge Reader Replacement: adım 3, 2 resimden 2.
    • Remove the two 15mm Phillips #1 screws holding the casing in place.
    • Remove the casing to reveal the cartridge reader.
  4. ColecoVision Cartridge Reader Replacement: adım 4, 3 resimden 1. ColecoVision Cartridge Reader Replacement: adım 4, 3 resimden 2. ColecoVision Cartridge Reader Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    Satın Al
    • Desolder the sides of the cartridge reader using the soldering iron and desolder pump.
    • Refer to this soldering technique guide for reference
    • Patiently wait for the cartridge reader to cool down after being desoldered.
    • It's very important to remove all the tin from the motherboard and cartridge reader before lifting it from the motherboard. Failure to do so could damage the motherboard.
    • Carefully lift up the cartridge reader. A plastic spudger might be helpful in order to easily remove the cartridge reader.
Sonuç
Anastazia Kidder
109 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,516
