Ana içeriğe geç
ColecoVision Motherboard Replacement
Neye ihtiyacın var
  1. ColecoVision Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Start by laying the console face down.
    • Remove the eight 15mm Phillips #1 screws from the bottom of the device.
  2. ColecoVision Motherboard Replacement: adım 2, 2 resimden 1. ColecoVision Motherboard Replacement: adım 2, 2 resimden 2.
    • Flip the console back over.
    • Lift the front panel off. I would reccomended using a metal spudger along the rim of the top to safely remove it and set it aside.
  3. ColecoVision Motherboard Replacement: adım 3, 2 resimden 1. ColecoVision Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the two 15mm Phillips #1 screws holding the casing in place.
    • Carefully lift the casing from the motherboard.
  4. ColecoVision Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the center Phillips #1 screw near the cartridge slot.
    • Remove the second Phillips #1 screw near the RAM chips.
    • Carefully lift and remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Krystalina
121 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Rose Fall 2018 UW Tacoma, Team S1-G2, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 35
Her zaman: 1,595
