Ana içeriğe geç
Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement
Neye ihtiyacın var
  1. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Battery: adım 1, 2 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Battery: adım 1, 2 resimden 2.
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 2, 1 resimden 1.
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 3, 2 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 3, 2 resimden 2.
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 4, 3 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 4, 3 resimden 2. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 4, 3 resimden 3.
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Main Power Board: adım 5, 2 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Main Power Board: adım 5, 2 resimden 2.
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 6, 2 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 6, 2 resimden 2.
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 7, 3 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 7, 3 resimden 2. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: adım 7, 3 resimden 3.
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
  8. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Lantern Power Switch: adım 8, 2 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Lantern Power Switch: adım 8, 2 resimden 2.
    • Remove the switch by pushing down on the ends while simultaneously pulling it out of the slot.
    • When removing the switch, make sure to depress the inner clips when removing from the device. Be careful, do not force the switch from the base of the lantern.
Sonuç
Mathew Merrick
169 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 949
