Ana içeriğe geç
Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement
Neye ihtiyacın var
  1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: adım 1, 2 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Battery: adım 1, 2 resimden 2.
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 2, 1 resimden 1.
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 3, 2 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 3, 2 resimden 2.
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 4, 3 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 4, 3 resimden 2. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 4, 3 resimden 3.
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: adım 5, 2 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement, Main Power Board: adım 5, 2 resimden 2.
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 6, 2 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 6, 2 resimden 2.
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 7, 3 resimden 1. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 7, 3 resimden 2. Coleman Rechargeable Fluorescent Twin Tube Main Power Board Replacement: adım 7, 3 resimden 3.
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
Sonuç
Mathew Merrick
169 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 588
