Ana içeriğe geç
ComNet Ericsson Panther 600P Buttons Replacement
Neye ihtiyacın var
  1. ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: adım 1, 3 resimden 1. ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: adım 1, 3 resimden 2. ComNet Ericsson Panther 600P Buttons Replacement, Locate the release button.: adım 1, 3 resimden 3.
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
    FixBot'a Sor
    Yorum Ekle
  2. ComNet Ericsson Panther 600P Buttons Replacement, Antenna: adım 2, 1 resimden 1.
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
    FixBot'a Sor
    Yorum Ekle
  3. ComNet Ericsson Panther 600P Buttons Replacement, Dials: adım 3, 1 resimden 1.
    • Pull up on the dials to remove them from the underlying pegs.
    FixBot'a Sor
    Yorum Ekle
  4. ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: adım 4, 3 resimden 1. ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: adım 4, 3 resimden 2. ComNet Ericsson Panther 600P Buttons Replacement, Exterior Case: adım 4, 3 resimden 3.
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
    FixBot'a Sor
    Yorum Ekle
  5. ComNet Ericsson Panther 600P Buttons Replacement, Remove Buttons: adım 5, 2 resimden 1. ComNet Ericsson Panther 600P Buttons Replacement, Remove Buttons: adım 5, 2 resimden 2.
    • Grip the corner of the button pad and gently peal it away from the faceplate.
    • Clean off any sticky residue and/or replace the buttons.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 560
