Giriş
With a few tools, a little bit of time, and a moderate degree of commitment, you can replace a damaged display on ComNet Ericsson Panther 600P.
Neye ihtiyacın var
Look for the release button on the back of the radio.
Press the button and pull down on the battery at the same time. The battery will come free.
Using a T15 Torx screwdriver, unscrew the two screws.
Using a plastic opening tool, pry the internal case from the external case.
Bu adımda kullanılan alet:Tweezers$4.99
Pull ribbon with tweezers to detach from back panel.
