Ana içeriğe geç
ComNet Ericsson Panther 600P Exterior Case Disassembly
Neye ihtiyacın var
  1. ComNet Ericsson Panther 600P Exterior Case Disassembly, Locate the release button.: adım 1, 3 resimden 1. ComNet Ericsson Panther 600P Exterior Case Disassembly, Locate the release button.: adım 1, 3 resimden 2. ComNet Ericsson Panther 600P Exterior Case Disassembly, Locate the release button.: adım 1, 3 resimden 3.
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Exterior Case Disassembly, Antenna: adım 2, 1 resimden 1.
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Exterior Case Disassembly, Dials: adım 3, 1 resimden 1.
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Exterior Case Disassembly, Exterior Case: adım 4, 3 resimden 1. ComNet Ericsson Panther 600P Exterior Case Disassembly, Exterior Case: adım 4, 3 resimden 2. ComNet Ericsson Panther 600P Exterior Case Disassembly, Exterior Case: adım 4, 3 resimden 3.
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 159
