Ana içeriğe geç
Comfort Zone CZ6C Fan Blades Replacement
Neye ihtiyacın var
  1. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: adım 1, 3 resimden 1. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: adım 1, 3 resimden 2. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: adım 1, 3 resimden 3.
    • The metal cage is kept in place by three plastic tabs on the plastic body. Focus your pulling around these tabs to make the job easier.
    • In order to remove the metal cage, place one hand firmly on the back plastic body and your other hand on the metal cage.
    • Now work your way around the edge of the fan cage and pull it away from the plastic body.
  2. Comfort Zone CZ6C Fan Blades Replacement: adım 2, 2 resimden 1. Comfort Zone CZ6C Fan Blades Replacement: adım 2, 2 resimden 2.
    • To remove the fan blade, reach behind it and slowly pull it towards you.
    • If the fan blade axle has any hair or dirt, then clean it with a cloth to avoid further fan blade blockage.
    • If you are having difficulty removing the fan blade, then generously apply WD-40 to the fan blade axle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Samantha Galicinao
289 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-5, Forte Spring 2015 Cal Poly, Team 17-5, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G5
4 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where does one buy the replacement blades?
Frank Gould - Yanıt
where does one buy the replacement blades??
Luis Marrero - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 5,992
