Ana içeriğe geç
Comment forcer le redémarrage de l'iPhone X
Neye ihtiyacın var
  1. Comment forcer le redémarrage de l'iPhone X, Comment forcer le redémarrage de l'iPhone X: adım 1, 1 resimden 1.
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone X: adım 2, 1 resimden 1.
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
Bitiş Çizgisi
133 farklı kişi bu kılavuzu tamamladı.
14Kılavuz Yorumları
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - Yanıt
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - Yanıt
good share. thanks.
MelissaR - Yanıt
What is the other way?
sa sas - Yanıt
will it delete all data from my iPhone?
_TR0xuu_ - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 148
Son 30 gün: 729
Her zaman: 365,462
