Ana içeriğe geç
Commercial 8 Quart Bowl-Lift Stand Mixer - Base/Foot Assembly Replacement
Neye ihtiyacın var
    • Before starting ANY repair/disassembly of the mixer, make sure it is fully unplugged from the electrical outlet.
    • If this mixer is being used in a commercial environment, a LOTO tag can be affixed via the hole on one of the prongs on the mains plug to prevent accidental activation.
  1. Commercial 8 Quart Bowl-Lift Stand Mixer - Base/Foot Assembly Replacement, Removing the base/foot assembly: adım 2, 2 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Base/Foot Assembly Replacement, Removing the base/foot assembly: adım 2, 2 resimden 2.
    • Lay the mixer on its side, placing a dish towel or other soft material underneath to protect the finish.
    • Using a #3 Phillips screwdriver, remove the three screws (circled in yellow) attaching the base/foot assembly and mesh vent screen to the mixer column. Taking care to protect the mixer because the base/foot assembly will immediately come free from the mixer column when the last screw is removed.
    • Remove the mesh vent screen (noted in blue) and place it to the side for use during reassembly.
    • Begin reassembly with the replacement base/foot assembly.
Sonuç
PedroDaGr8
2.971 İtibar
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 125
