Ana içeriğe geç
Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement
Neye ihtiyacın var
    • Before starting ANY repair/disassembly of the mixer, make sure it is fully unplugged from the electrical outlet.
    • If this mixer is being used in a commercial environment, a LOTO tag can be affixed via the hole on one of the prongs on the mains plug to prevent accidental activation.
    • The speed/motor control assembly contains capacitors which can retain their charge for an indefinite amount of time. These capacitors can present a significant and potentially fatal shock hazard.
  1. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the trim band: adım 2, 1 resimden 1.
    • Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
    • Remove the trim band.
  2. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the motor housing: adım 3, 3 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the motor housing: adım 3, 3 resimden 2. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the motor housing: adım 3, 3 resimden 3.
    • Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
    • Remove the motor housing by lifting it straight up.
  3. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the Planetary Assembly: adım 4, 3 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the Planetary Assembly: adım 4, 3 resimden 2. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the Planetary Assembly: adım 4, 3 resimden 3.
    • Place a couple dish towels or other soft materials on the base to protect it from any potential impact.
    • Disconnect the planetary from the motor drive shaft by removing the retaining pin (circled in yellow). You can do this with a hammer and either a pin punch or a Torx T15 screwdriver. Simply hammer the punch/screwdriver on the pin until it comes out the other side.
    • If the planetary assembly doesn't fall out, you might have to give it a firm pull straight down to remove it.
  4. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the main planetary gear: adım 5, 2 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the main planetary gear: adım 5, 2 resimden 2.
    • Using a #2 Phillips Screwdriver, remove the four screws (circled in yellow).
    • When removing the last screw, make sure to place your hand under the planetary gear as it is heavy and will fall out immediately.
  5. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the motor support brackets: adım 6, 3 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the motor support brackets: adım 6, 3 resimden 2. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the motor support brackets: adım 6, 3 resimden 3.
    • There are two motor support brackets: one in front, one back (shown in the first image)
    • Each bracket is attached to the motor by two screws (one on each side).
    • Using a #2 Phillips screwdriver, remove the four screws (circled in yblue in the second and third images) which attach the two motor support brackets.
    • Take care to place your hand under the support bracket when removing the second screw as they will fall out and could damage the finish.
  6. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Disconnect the motor power cable: adım 7, 2 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Disconnect the motor power cable: adım 7, 2 resimden 2.
    • Disconnect the motor power cable by depressing the locking tab (circled in yellow) while pulling the connector apart.
    • Do not attempt to remove the hall effect sensor, the cord which attaches back by the fan, as it is much more easily removed at a later step.
  7. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the motor mounting screws: adım 8, 2 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the motor mounting screws: adım 8, 2 resimden 2.
    • Using a #2 Philips screwdriver, remove the four screws (indicated in yellow, two on each side) attaching the powertrain/motor to the mixer body.
    • Take care to support the motor as it is no longer connected to the mixer body and could damage the circuit board underneath
  8. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the hall effect sensor and powertrain/motor: adım 9, 2 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Powertrain/Motor Replacement, Remove the hall effect sensor and powertrain/motor: adım 9, 2 resimden 2.
    • Remove the hall effect sensor from its mount by pressing down on the tab indicated in the first picture and sliding it out.
    • Now that the powertrain/motor is fully disconnected from the mixer, remove it and place it to the side.
    • Begin the reassembly process with the new powertrain/motor
Sonuç
PedroDaGr8
3.059 İtibar
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 1,198
