Ana içeriğe geç
Commercial 8 Quart Bowl-Lift Stand Mixer - Switch Guard Replacement
Neye ihtiyacın var
    • Before starting ANY repair/disassembly of the mixer, make sure it is fully unplugged from the electrical outlet.
    • If this mixer is being used in a commercial environment, a LOTO tag can be affixed via the hole on one of the prongs on the mains plug to prevent accidental activation.
  1. Commercial 8 Quart Bowl-Lift Stand Mixer - Switch Guard Replacement, Remove the trim band: adım 2, 1 resimden 1.
    • Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
    • Remove the trim band.
  2. Commercial 8 Quart Bowl-Lift Stand Mixer - Switch Guard Replacement, Remove the motor housing: adım 3, 3 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Switch Guard Replacement, Remove the motor housing: adım 3, 3 resimden 2. Commercial 8 Quart Bowl-Lift Stand Mixer - Switch Guard Replacement, Remove the motor housing: adım 3, 3 resimden 3.
    • Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
    • Remove the motor housing by lifting it straight up.
  3. Commercial 8 Quart Bowl-Lift Stand Mixer - Switch Guard Replacement, Remove the old switch guard: adım 4, 3 resimden 1. Commercial 8 Quart Bowl-Lift Stand Mixer - Switch Guard Replacement, Remove the old switch guard: adım 4, 3 resimden 2. Commercial 8 Quart Bowl-Lift Stand Mixer - Switch Guard Replacement, Remove the old switch guard: adım 4, 3 resimden 3.
    • Using a #2 Phillips screwdriver, remove the single screw attaching the switch guard to the mixer body.
    • The second image shows the rough location of the screw, while the third image shows an unobstructed view of said screw.
Sonuç
PedroDaGr8
3.059 İtibar
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 365
