Neye ihtiyacın var
Turn the dial until the little green mark is set on the "OFF" option. Next disconnect the two testing leads by simply pulling them away from the body. Set these aside for later.
Unscrew the four Phillips screws that hold the back panel and carefully open it from either side and lay it besides the main body, try not to break the top led cable.
Disconnect the top led cable from the PCB and move everything aside.
4 farklı kişi bu kılavuzu tamamladı.
