Ana içeriğe geç
Commodore 64 3AG fuse Replacement
Neye ihtiyacın var
  1. Dikkatli ol: adımlar 1-2 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Commodore 64 3AG fuse Replacement, Removing screws: adım 1, 3 resimden 1. Commodore 64 3AG fuse Replacement, Removing screws: adım 1, 3 resimden 2. Commodore 64 3AG fuse Replacement, Removing screws: adım 1, 3 resimden 3.
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 3AG fuse Replacement, Opening: adım 2, 2 resimden 1. Commodore 64 3AG fuse Replacement, Opening: adım 2, 2 resimden 2.
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: adım 3, 2 resimden 1. Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: adım 3, 2 resimden 2.
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
    • In this picture, the power indication LED (connected to the black and red wires) is not fastened to the keyboard panel, yours might be different.
  4. Commodore 64 3AG fuse Replacement, Locate 3AG fuse: adım 4, 1 resimden 1.
    • 2. Find the 3AG fuse located next to the joystick ports and On/Off switch
  5. Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: adım 5, 2 resimden 1. Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: adım 5, 2 resimden 2.
    • 3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
    • * Replace the 3AG fuse by inserting the new fuse and letting it pop into the clip
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Silvanus Clarke
656 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G6
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 3,618
