Ana içeriğe geç
Commodore 64 Central Processing Unit (CPU) Replacement
Neye ihtiyacın var
  1. Dikkatli ol: adımlar 1-2 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: adım 1, 3 resimden 1. Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: adım 1, 3 resimden 2. Commodore 64 Central Processing Unit (CPU) Replacement, Removing screws: adım 1, 3 resimden 3.
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 Central Processing Unit (CPU) Replacement, Opening: adım 2, 2 resimden 1. Commodore 64 Central Processing Unit (CPU) Replacement, Opening: adım 2, 2 resimden 2.
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 Central Processing Unit (CPU) Replacement, Detach Keyboard from the motherboard: adım 3, 2 resimden 1. Commodore 64 Central Processing Unit (CPU) Replacement, Detach Keyboard from the motherboard: adım 3, 2 resimden 2.
    • 1. Detach the multi-colored wire bundles connected to the motherboard.
  4. Commodore 64 Central Processing Unit (CPU) Replacement, Locate the CPU: adım 4, 1 resimden 1.
    • Locate the CPU chip which is labeled 'MOS 6510 3782'
  5. Commodore 64 Central Processing Unit (CPU) Replacement, Removing the CPU chip: adım 5, 2 resimden 1. Commodore 64 Central Processing Unit (CPU) Replacement, Removing the CPU chip: adım 5, 2 resimden 2.
    • 3. Loosen the CPU chip with a Phillips screwdriver. Then use your hand to pry up the CPU chip from the motherboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Silvanus Clarke
656 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G6
4 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
there are two problems
1. Use an spudger for lifting the C.P.U instead of an screw driver bit to help alleviate concerns of bending the pins,
2. There is an step missing which involves cutting the tape seen here.
- Jordan .F
Jordan Fryman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 2,658
