Giriş
The Video Interface Controller (VIC) is is the graphics chip for the C64.
Neye ihtiyacın var
Adım 1 Removing screws
Dikkatli ol: adımlar 1-2 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
1. Remove three 6.75mm ph2 screw heads from the casing
1. Detach the multi-colored wire bundles that's connected to the motherboard
2. Without using any tools prop up the metal VIC plate with both hands to expose the VIC chip.
3. Use a Phillips screwdriver to pry up the VIC chip. Then, use your hands and with small pressure pull it away to remove it from the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
