Ana içeriğe geç
Commodore 64 VIC Chip Replacement
Neye ihtiyacın var
    1. Commodore 64 VIC Chip Replacement, Removing screws: adım 1, 3 resimden 1. Commodore 64 VIC Chip Replacement, Removing screws: adım 1, 3 resimden 2. Commodore 64 VIC Chip Replacement, Removing screws: adım 1, 3 resimden 3.
      • 1. Remove three 6.75mm ph2 screw heads from the casing
      FixBot'a Sor
      Yorum Ekle
    2. Commodore 64 VIC Chip Replacement, Opening: adım 2, 2 resimden 1. Commodore 64 VIC Chip Replacement, Opening: adım 2, 2 resimden 2.
      • 2. Split the case of the C64 open by pulling up on the case towards you
      • Do not pull too hard that you break the clips.
      FixBot'a Sor
      Yorum Ekle
    1. Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: adım 3, 2 resimden 1. Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: adım 3, 2 resimden 2.
      • 1. Detach the multi-colored wire bundles that's connected to the motherboard
      FixBot'a Sor
      Yorum Ekle
    2. Commodore 64 VIC Chip Replacement, Pull up the VIC plate: adım 4, 2 resimden 1. Commodore 64 VIC Chip Replacement, Pull up the VIC plate: adım 4, 2 resimden 2.
      • 2. Without using any tools prop up the metal VIC plate with both hands to expose the VIC chip.
      FixBot'a Sor
      Yorum Ekle
    3. Commodore 64 VIC Chip Replacement, Removing the Chip: adım 5, 2 resimden 1. Commodore 64 VIC Chip Replacement, Removing the Chip: adım 5, 2 resimden 2.
      • 3. Use a Phillips screwdriver to pry up the VIC chip. Then, use your hands and with small pressure pull it away to remove it from the motherboard.
      • You can insert a new VIC chip by making it clip back in on the board
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Silvanus Clarke
677 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G6
4 Üyeler
35 adet Kılavuz yazıldı
1Rehber Yorum
It's awesome to see that people care enough about these machines to make repair guides about them! Great job!
[deleted] - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 52
Her zaman: 5,620
