Giriş
The CFL lightbulb has taken over in today's suburban home. Using less than 30 watts to power it and having the same light output as a standard 100 watt incandescent bulb, the CFL is certainly a "bright idea".
  1. Locate the bad bulb and remove it from the socket. This is achieved by grabbing the bulb lightly and rotating counter-clockwise. The bulb may be hot. If so, use gloves, or wait for it to cool.
    • Locate the bad bulb and remove it from the socket. This is achieved by grabbing the bulb lightly and rotating counter-clockwise.
    • The bulb may be hot. If so, use gloves, or wait for it to cool.
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Procure a new lightbulb, either from a hardware store, or wherever it is you keep new ones.
    • Procure a new lightbulb, either from a hardware store, or wherever it is you keep new ones.
    • Install the new lightbulb into the socket, this time rotating clockwise.
    • Be sure the power to the socket is turned off before you preform this step. Failure to do so my cause injury.
  4. Turn the power on to the light socket by means of a switch or knob.
    • Turn the power on to the light socket by means of a switch or knob.
    • Congratulations! You have successfully changed a lightbulb! Reward your efforts by getting a cold beverage of your choice.
Bitiş Çizgisi
9 farklı kişi bu kılavuzu tamamladı.
WiseGeek
1.235 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
here is other way to relight burnt cfl bulb : http://andre-elektrik.blogspot.co.id/201...
Andrei Elektrik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 6
Her zaman: 7,347
