Ana içeriğe geç
Compaq Evo N1000v LED Cover Replacement
Neye ihtiyacın var
  1. Compaq Evo N1000v LED Cover Replacement, LED Cover: adım 1, 1 resimden 1.
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v LED Cover Replacement: adım 2, 1 resimden 1.
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v LED Cover Replacement: adım 3, 1 resimden 1.
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v LED Cover Replacement: adım 4, 1 resimden 1.
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v LED Cover Replacement: adım 5, 1 resimden 1.
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v LED Cover Replacement: adım 6, 1 resimden 1.
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v LED Cover Replacement: adım 7, 1 resimden 1.
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v LED Cover Replacement: adım 8, 2 resimden 1. Compaq Evo N1000v LED Cover Replacement: adım 8, 2 resimden 2.
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
Sonuç
kim
59 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-74, Johann Spring 2010 Cal Poly, Team 29-74, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G74
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 2,750
