Ana içeriğe geç
Compaq Evo N1000v Rear Fan Replacement
Neye ihtiyacın var
    1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: adım 1, 1 resimden 1.
      • Carefully remove the screws located inside the red circles.
      FixBot'a Sor
      Yorum Ekle
    2. Compaq Evo N1000v Rear Fan Replacement: adım 2, 2 resimden 1. Compaq Evo N1000v Rear Fan Replacement: adım 2, 2 resimden 2.
      • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
      • Push down on the spudger to lift the LED display upward.
      • Do this on both the left and right sides of the device as shown in the images.
      FixBot'a Sor
      Yorum Ekle
    3. Compaq Evo N1000v Rear Fan Replacement: adım 3, 1 resimden 1.
      • Completely remove the LED display panel from the device.
      FixBot'a Sor
      Yorum Ekle
    4. Compaq Evo N1000v Rear Fan Replacement: adım 4, 1 resimden 1.
      • Lift the keyboard up from the back end as shown in the image.
      FixBot'a Sor
      Yorum Ekle
    5. Compaq Evo N1000v Rear Fan Replacement: adım 5, 1 resimden 1.
      • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
      FixBot'a Sor
      Yorum Ekle
    6. Compaq Evo N1000v Rear Fan Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
      • Repeat this action on the right side of the lock.
      FixBot'a Sor
      Yorum Ekle
    7. Compaq Evo N1000v Rear Fan Replacement: adım 7, 1 resimden 1.
      • Pull the keyboard upward to remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    8. Compaq Evo N1000v Rear Fan Replacement: adım 8, 1 resimden 1.
      • Unscrew the 3 screws as shown in the photo.
      FixBot'a Sor
      Yorum Ekle
    9. Compaq Evo N1000v Rear Fan Replacement: adım 9, 1 resimden 1.
      • Remove the cable with the grip tweezers as shown in the photo.
      FixBot'a Sor
      Yorum Ekle
    10. Compaq Evo N1000v Rear Fan Replacement: adım 10, 1 resimden 1.
      • Remove the rear fan.
      • Repeat these steps in reverse order to install the new rear fan.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
ryan
470 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014 üyesi
UMASSD-VIJAYBHASKAR-S14S2G1
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 817
