Ana içeriğe geç
Compaq Mini 110 Display Assembly Replacement
Neye ihtiyacın var
  1. Compaq Mini 110 Display Assembly Replacement, Battery: adım 1, 2 resimden 1. Compaq Mini 110 Display Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    FixBot'a Sor
    Yorum Ekle
  2. Compaq Mini 110 Display Assembly Replacement: adım 2, 3 resimden 1. Compaq Mini 110 Display Assembly Replacement: adım 2, 3 resimden 2. Compaq Mini 110 Display Assembly Replacement: adım 2, 3 resimden 3.
    • Push both tabs inward simultaneously and slide the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Compaq Mini 110 Display Assembly Replacement, RAM: adım 3, 2 resimden 1. Compaq Mini 110 Display Assembly Replacement, RAM: adım 3, 2 resimden 2.
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    FixBot'a Sor
    Yorum Ekle
  4. Compaq Mini 110 Display Assembly Replacement: adım 4, 1 resimden 1.
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    FixBot'a Sor
    Yorum Ekle
  5. Compaq Mini 110 Display Assembly Replacement, Keyboard: adım 5, 2 resimden 1. Compaq Mini 110 Display Assembly Replacement, Keyboard: adım 5, 2 resimden 2.
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    FixBot'a Sor
    Yorum Ekle
  6. Compaq Mini 110 Display Assembly Replacement: adım 6, 2 resimden 1. Compaq Mini 110 Display Assembly Replacement: adım 6, 2 resimden 2.
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    FixBot'a Sor
    Yorum Ekle
  7. Compaq Mini 110 Display Assembly Replacement: adım 7, 2 resimden 1. Compaq Mini 110 Display Assembly Replacement: adım 7, 2 resimden 2.
    • Unscrew the screw for the bottom case located in the RAM compartment.
    FixBot'a Sor
    Yorum Ekle
  8. Compaq Mini 110 Display Assembly Replacement: adım 8, 2 resimden 1. Compaq Mini 110 Display Assembly Replacement: adım 8, 2 resimden 2.
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  9. Compaq Mini 110 Display Assembly Replacement, Hard Drive: adım 9, 1 resimden 1.
    • Remove the three screws holding the panel in place.
    FixBot'a Sor
    Yorum Ekle
  10. Compaq Mini 110 Display Assembly Replacement: adım 10, 2 resimden 1. Compaq Mini 110 Display Assembly Replacement: adım 10, 2 resimden 2.
    • Pull up on the tab to remove the hard drive.
    FixBot'a Sor
    Yorum Ekle
  11. Compaq Mini 110 Display Assembly Replacement, Top Cover: adım 11, 1 resimden 1.
    • Remove the eight screws that are from the plastic top cover.
    FixBot'a Sor
    Yorum Ekle
  12. Compaq Mini 110 Display Assembly Replacement: adım 12, 3 resimden 1. Compaq Mini 110 Display Assembly Replacement: adım 12, 3 resimden 2. Compaq Mini 110 Display Assembly Replacement: adım 12, 3 resimden 3.
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
    FixBot'a Sor
    Yorum Ekle
  13. Compaq Mini 110 Display Assembly Replacement: adım 13, 2 resimden 1. Compaq Mini 110 Display Assembly Replacement: adım 13, 2 resimden 2.
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
    FixBot'a Sor
    Yorum Ekle
  14. Compaq Mini 110 Display Assembly Replacement, Display Assembly: adım 14, 3 resimden 1. Compaq Mini 110 Display Assembly Replacement, Display Assembly: adım 14, 3 resimden 2. Compaq Mini 110 Display Assembly Replacement, Display Assembly: adım 14, 3 resimden 3.
    • Remove the four screws that keep the bottom of the hinges attached to the base.
    FixBot'a Sor
    Yorum Ekle
  15. Compaq Mini 110 Display Assembly Replacement: adım 15, 3 resimden 1. Compaq Mini 110 Display Assembly Replacement: adım 15, 3 resimden 2. Compaq Mini 110 Display Assembly Replacement: adım 15, 3 resimden 3.
    • Pry off the top plastic cover of the display assembly.
    • The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
    • There is adhesive tape holding the cover on.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
alea
1.429 İtibar
14 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-2, Maness Fall 2010 Cal Poly, Team 22-2, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G2
6 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 34
Her zaman: 7,737
