Ana içeriğe geç
Compaq Mini 110 Keyboard Replacement
Neye ihtiyacın var
  1. Compaq Mini 110 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Compaq Mini 110 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    FixBot'a Sor
    Yorum Ekle
  2. Compaq Mini 110 Keyboard Replacement: adım 2, 3 resimden 1. Compaq Mini 110 Keyboard Replacement: adım 2, 3 resimden 2. Compaq Mini 110 Keyboard Replacement: adım 2, 3 resimden 3.
    • Push both tabs inward simultaneously and slide the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Compaq Mini 110 Keyboard Replacement, RAM: adım 3, 2 resimden 1. Compaq Mini 110 Keyboard Replacement, RAM: adım 3, 2 resimden 2.
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    FixBot'a Sor
    Yorum Ekle
  4. Compaq Mini 110 Keyboard Replacement: adım 4, 1 resimden 1.
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    FixBot'a Sor
    Yorum Ekle
  5. Compaq Mini 110 Keyboard Replacement, Keyboard: adım 5, 2 resimden 1. Compaq Mini 110 Keyboard Replacement, Keyboard: adım 5, 2 resimden 2.
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    FixBot'a Sor
    Yorum Ekle
  6. Compaq Mini 110 Keyboard Replacement: adım 6, 2 resimden 1. Compaq Mini 110 Keyboard Replacement: adım 6, 2 resimden 2.
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    FixBot'a Sor
    Yorum Ekle
  7. Compaq Mini 110 Keyboard Replacement: adım 7, 2 resimden 1. Compaq Mini 110 Keyboard Replacement: adım 7, 2 resimden 2.
    • Unscrew the screw for the bottom case located in the RAM compartment.
    FixBot'a Sor
    Yorum Ekle
  8. Compaq Mini 110 Keyboard Replacement: adım 8, 2 resimden 1. Compaq Mini 110 Keyboard Replacement: adım 8, 2 resimden 2.
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
alea
1.429 İtibar
14 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-2, Maness Fall 2010 Cal Poly, Team 22-2, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G2
6 Üyeler
20 adet Kılavuz yazıldı
3Kılavuz Yorumları
hi, steps 5 and 6 are not needed. not sure about removing RAM either. If I look on my removed keyboard, all I see are three places for screws - those located nearby battery socket.
Petr Gebelt - Yanıt Paylaş
I think steps 3,4,5,6,7 are not needed! The essential problem in removing the keyboard is not shown: how to lift the keyboard! Use the flat side or back of a screwdriver to push the metal strips shown in step 8 up (in the direction of the keyboard) to lift the keyboard. Put your fingers under the edge of the keyboard and pull gently but firmly. There is some resistance of the holding cover.
See also: https://www.youtube.com/watch?v=nELBz1VB...
Hans Donck - Yanıt Paylaş
Thank you so much for the link!
Alex - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 17,404
