Giriş
If you want to change not working Hard Disk Drive (HDD) or you want to upgrade it, this manual will help you to do this.
Neye ihtiyacın var
Videoya Genel Bakış
Remove the 4x screws and take out the HDD.
Disconnect the SATA cable.
The Hard Drive is held in the HDD Caddy by 4x screws.
i am looking for connector
Hi, got some pats you are searching for by searching "HDD SATA connector for HP Compaq CQ58" on Google. The HDD SATA connector of this laptop can still be found nowaday.
(I searched HP Compaq, because Compaq has been acquired by HP)
Good day.
Brendan -
7 farklı kişi bu kılavuzu tamamladı.
2 Yorum
SSDs may not work. Tried two different ones already on one of these (a Crucial and an A-Data), and no luck. Not sure if it has to do with missing BIOS/UEFI options, or a whitelist of parts in said firmware.
thanks for this info!
good
100% nice
muhamad amin - Yanıt
